[Script]Modulo XRXS.
Mensagem por helivelton » Qua Jan 02, 2008 11:06 am
Um outro Modulo, bem legal!
################### Modulo XRXS L5 e L6 #########################
#Script necessário para usar alguns outros scripts do XRXS ######
module XRXS
def XRXS.element_check(set, element_name)
returnar = [false, 0, 0, []]
return returnar if !set.is_a?(Array) or set.size == 0 or element_name == ""
for i in set
if $data_system.elements =~ /^#{element_name}([+-]?[0-9]+)?(%)?/
returnar[0] = true
if $2 == nil
returnar[1] += $1.to_i
returnar[3].push($1.to_i)
else
returnar[2] += $1.to_i
return returnar
def XRXS.element_include?(set, element_name)
return element_check(set, element_name)[0]
def XRXS.element_amount(set, element_name)
return element_check(set, element_name)[1]
def XRXS.element_percent(set, element_name)
return element_check(set, element_name)[2]
def XRXS.element_numbers(set, element_name)
return element_check(set, element_name)[3]
# --- XRXS. ???????? ---
class Game_Battler
def skill_element_set(skill)
return skill.nil? ? [] : skill.element_set
def equip_element_set
return self.element_set + self.guard_element_set
def guard_element_set
return []
class Game_Actor < Game_Battler
set = []
for id in self.armor_ids
next if id.nil?
armor = $data_armors[id]
set += (armor != nil ? armor.guard_element_set : [])
return set
# ? ?? ID??
def weapon_ids
unless self.is_a?(Game_Actor)
return []
ids = @weapon_ids != nil ? @weapon_ids : []
ids[0] = @weapon_id
return ids
# ? ?? ID??
def armor_ids
return []
ids = @armor_ids != nil ? @armor_ids : []
ids[0] = @armor1_id
ids[1] = @armor2_id
ids[2] = @armor3_id
ids[3] = @armor4_id
return ids
def equipments
equipments = []
self.weapon_ids.each {|id| equipments.push($data_weapons[id])}
self.armor_ids.each {|id| equipments.push($data_armors[id])}
return equipments
def equiping?(item)
case item
when RPG::Weapon
return self.weapon_ids.include?(item.id)
when RPG::Armor
return self.armor_ids.include?(item.id)
else
return false
<a href="http://rpg_legacy.queroumforum.com/viewtopic.php?t=20">Fonte</a>
