[Script]Ring Menu(Modificado).
Mensagem por helivelton » Qua Jan 02, 2008 11:14 am
Este script modifica o menu do game, deixando ele bem diferente!
A um script igual no Help do RPG Maker, porém este está com mais conteudo!
# ¦ Ring Menu - Show Player Location - Release #1 (Edited By Dubealex)
# For more infos and update, visit:
# rmxp.dubealex.com [OR] X-RPG V2 Forum
# Original Ring Menu by: ?? (From XRXS)
# Original Edit and Fix by: Maki
# Show Player Location Version by: Dubealex
# You can customize this script at line #35 - Have fun !!
# If you want to show more stuff, its easy to do, just ask, and I will
release
# new version of this edited script !
# alex@dubealex.com
# ? CLASS Scene_Menu Begins
class Scene_Menu
# ?œ ƒIƒuƒWƒFƒNƒg?‰Šú‰»
# menu_index : ƒRƒ}ƒ“ƒh‚̃J?[ƒ\ƒ‹?‰ŠúˆÊ’u
def initialize(menu_index = 0)
@menu_index = menu_index
$location_text=[]
$window_size=[]
$ring_menu_text=[]
$chara_select=[]
@window_opacity=[]
@chara_select=[]
@window_position=[]
# ¦ Ring Menu Customization Section: (By Dubealex)
# Those variables defines how the script will act.
# Simply change the value by those you want.
# Remember that changing the font size has its limitation due to text space
allocation.
# ? TEXT SETTINGS FOR SHOW PLAYER LOCATION WINDOW:
$location_text[0]="Tahoma" # Font Type
$location_text[1]=22 # Font Size
$location_text[2]=6 # Location Title Color
$location_text[4]=0 # Map Name Color
$location_text[3]="Localização:" # Customize the "Location" Title Text
# ? SHOW LOCATION WINDOW SETTINS:
@show_location_window=true #Set to false to not use it !
@window_opacity[0]=255 # Border Opacity
@window_opacity[1]=130 # Background Opacity
$window_location_skin="001-Blue01" # Window Skin
@window_position[0]=20 # X Axis Position
@window_position[1]=20 # Y Axis Position
$window_size[0]=160 # Lengh
$window_size[1]=96 # Heigh
# ? TEXT SETTINGS FOR INSIDE THE RING MENU:
$ring_menu_text[0]="Tahoma" # Font Type
$ring_menu_text[7]=0 # Font Color
$ring_menu_text[8]=22 # Font Size
$ring_menu_text[1]="Items" # Items Menu Text
$ring_menu_text[2]="Habilidades" # Skills Menu Text
$ring_menu_text[3]="Equipamento" # Equip Menu Text
$ring_menu_text[4]="Status" # Stats Menu Text
$ring_menu_text[5]="Salvar" # Save Menu Text
$ring_menu_text[6]="Sair" # Quit Menu Text
# ? CHARACTER SELECTION WINDOW SETTINGS :
@chara_select[0]=400 # X Axis Position
@chara_select[1]=0 # Y Axis Position
$chara_select[0]="Tahoma" # Font Type
$chara_select[1]=0 # Font Color
$chara_select[5]=22 # Font Size
$chara_select[2]=255 # Window Border Opacity
$chara_select[3]=130 # Window Background Opacity
$chara_select[4]="001-Blue01" # Window Skin to use
# ?œ ƒ?ƒCƒ“?ˆ—?
def main
# Show Player Location Feature:
if @show_location_window==true
@window_location = Window_Location.new
@window_location.x = @window_position[0]
@window_location.y = @window_position[1]
@window_location.opacity = @window_opacity[0]
@window_location.back_opacity = @window_opacity[1]
#End of Show Player Location
# ƒXƒvƒ‰ƒCƒgƒZƒbƒg‚ð?ì?¬
@spriteset = Spriteset_Map.new
# ƒRƒ}ƒ“ƒhƒEƒBƒ“ƒhƒE‚ð?ì?¬
px = $game_player.screen_x - 15
py = $game_player.screen_y - 24
@command_window = Window_RingMenu.new(px,py)
@command_window.index = @menu_index
# ƒp?[ƒeƒB?l?”‚ª 0 ?l‚Ì?ê?‡
if $game_party.actors.size == 0
# ƒAƒCƒeƒ€?AƒXƒLƒ‹?A‘•”õ?AƒXƒe?[ƒ^ƒX‚𖳌ø‰»
@command_window.disable_item(0)
@command_window.disable_item(1)
@command_window.disable_item(2)
@command_window.disable_item(3)
@command_window.z = 100
# ƒZ?[ƒu‹ÖŽ~‚Ì?ê?‡
if $game_system.save_disabled
# ƒZ?[ƒu‚𖳌ø‚É‚·‚é
@command_window.disable_item(4)
# ƒXƒe?[ƒ^ƒXƒEƒBƒ“ƒhƒE‚ð?ì?¬
@status_window = Window_RingMenuStatus.new
@status_window.x = @chara_select[0]
@status_window.y = @chara_select[1]
@status_window.z = 200
@status_window.opacity=$chara_select[2]
@status_window.back_opacity=$chara_select[3]
@status_window.visible = false
# ƒgƒ‰ƒ“ƒWƒVƒ‡ƒ“ŽÀ?s
Graphics.transition
# ƒ?ƒCƒ“ƒ‹?[ƒv
loop do
# ƒQ?[ƒ€‰æ–Ê‚ð?X?V
Graphics.update
# “ü—Í?î•ñ‚ð?X?V
Input.update
# ƒtƒŒ?[ƒ€?X?V
update
# ‰æ–Ê‚ª?Ø‚è‘Ö‚í‚Á‚½‚烋?[ƒv‚ð’†’f
if $scene != self
break
# ƒgƒ‰ƒ“ƒWƒVƒ‡ƒ“?€”õ
Graphics.freeze
# ƒXƒvƒ‰ƒCƒgƒZƒbƒg‚ð‰ð•ú
@spriteset.dispose
# ƒEƒBƒ“ƒhƒE‚ð‰ð•ú
@window_location.dispose
@command_window.dispose
@status_window.dispose
# ?œ ƒtƒŒ?[ƒ€?X?V
def update
# ƒEƒBƒ“ƒhƒE‚ð?X?V
@window_location.update
@command_window.update
@status_window.update
# ƒRƒ}ƒ“ƒhƒEƒBƒ“ƒhƒE‚ªƒAƒNƒeƒBƒu‚Ì?ê?‡: update_command ‚ðŒÄ‚Ô
if @command_window.active
update_command
return
# ƒXƒe?[ƒ^ƒXƒEƒBƒ“ƒhƒE‚ªƒAƒNƒeƒBƒu‚Ì?ê?‡: update_status ‚ðŒÄ‚Ô
if @status_window.active
update_status
return
# ?œ ƒtƒŒ?[ƒ€?X?V (ƒRƒ}ƒ“ƒhƒEƒBƒ“ƒhƒE‚ªƒAƒNƒeƒBƒu‚Ì?ê?‡)
def update_command
# B ƒ{ƒ^ƒ“‚ª‰Ÿ‚³‚ꂽ?ê?‡
if Input.trigger?(Input::B)
# ƒLƒƒƒ“ƒZƒ‹ SE ‚ð‰‰‘t
$game_system.se_play($data_system.cancel_se)
# ƒ}ƒbƒv‰æ–Ê‚É?Ø‚è‘Ö‚¦
$scene = Scene_Map.new
return
# C ƒ{ƒ^ƒ“‚ª‰Ÿ‚³‚ꂽ?ê?‡
if Input.trigger?(Input::C)
# ƒp?[ƒeƒB?l?”‚ª 0 ?l‚Å?AƒZ?[ƒu?AƒQ?[ƒ€?I—¹ˆÈŠO‚̃Rƒ}ƒ“ƒh‚Ì?ê?‡
if $game_party.actors.size == 0 and @command_window.index <4>= 2
# ƒuƒU?[ SE ‚ð‰‰‘t
$game_system.se_play($data_system.buzzer_se)
return
# Œˆ’è SE ‚ð‰‰‘t
$game_system.se_play($data_system.decision_se)
# ƒXƒLƒ‹‰æ–Ê‚É?Ø‚è‘Ö‚¦
$scene = Scene_Skill.new(@status_window.index)
when 2 # ‘•”õ
# Œˆ’è SE ‚ð‰‰‘t
# ‘•”õ‰æ–Ê‚É?Ø‚è‘Ö‚¦
$scene = Scene_Equip.new(@status_window.index)
when 3 # ƒXƒe?[ƒ^ƒX
# Œˆ’è SE ‚ð‰‰‘t
# ƒXƒe?[ƒ^ƒX‰æ–Ê‚É?Ø‚è‘Ö‚¦
$scene = Scene_Status.new(@status_window.index)
return
# ? CLASS Scene_Menu Ends
# ? CLASS Window_RingMenu Begins
class Window_RingMenu < Window_Base
# ?› ƒNƒ‰ƒX’è?”
STARTUP_FRAMES = 20
MOVING_FRAMES = 5
RING_R = 64
ICON_ITEM = RPG::Cache.icon("034-Item03")
ICON_SKILL = RPG::Cache.icon("044-Skill01")
ICON_EQUIP = RPG::Cache.icon("001-Weapon01")
ICON_STATUS = RPG::Cache.icon("050-Skill07")
ICON_SAVE = RPG::Cache.icon("038-Item07")
ICON_EXIT = RPG::Cache.icon("046-Skill03")
ICON_DISABLE= RPG::Cache.icon("")
SE_STARTUP = "056-Right02"
MODE_START = 1
MODE_WAIT = 2
MODE_MOVER = 3
MODE_MOVEL = 4
# ?› ƒAƒNƒZƒT
attr_accessor :index
def initialize( center_x, center_y )
super(0, 0, 640, 480)
self.contents = Bitmap.new(width-32, height-32)
self.contents.font.name = $ring_menu_text[0]
self.contents.font.color = text_color($ring_menu_text[7])
self.contents.font.size = $ring_menu_text[8]
self.opacity = 0
self.back_opacity = 0
s1 = $ring_menu_text[1]
s2 = $ring_menu_text[2]
s3 = $ring_menu_text[3]
s4 = $ring_menu_text[4]
s5 = $ring_menu_text[5]
s6 = $ring_menu_text[6]
@commands = [ s1, s2, s3, s4, s5, s6 ]
@item_max = 6
@index = 0
@items = [ ICON_ITEM, ICON_SKILL, ICON_EQUIP, ICON_STATUS, ICON_SAVE,
ICON_EXIT ]
@disabled = [ false, false, false, false, false, false ]
@cx = center_x - 16
@cy = center_y - 16
setup_move_start
refresh
# ?œ ƒtƒŒ?[ƒ€?X?V
def update
super
refresh
# ?œ ‰æ–Ê?Ä•`‰æ
def refresh
self.contents.clear
# ƒAƒCƒRƒ“‚ð•`‰æ
case @mode
when MODE_START
refresh_start
when MODE_WAIT
refresh_wait
when MODE_MOVER
refresh_move(1)
when MODE_MOVEL
refresh_move(0)
# ƒAƒNƒeƒBƒu‚ȃRƒ}ƒ“ƒh–¼•\Ž¦
rect = Rect.new(@cx - 272, @cy + 24, self.contents.width-32, 32)
self.contents.draw_text(rect, @commands[@index],1)
# ?› ‰æ–Ê?Ä•`‰æ(?‰Šú‰»Žž)
def refresh_start
d1 = 2.0 * Math::PI / @item_max
d2 = 1.0 * Math::PI / STARTUP_FRAMES
r = RING_R - 1.0 * RING_R * @steps / STARTUP_FRAMES
for i in 0...@item_max
j = i - @index
d = d1 * j + d2 * @steps
x = @cx + ( r * Math.sin( d ) ).to_i
y = @cy - ( r * Math.cos( d ) ).to_i
draw_item(x, y, i)
@steps -= 1
if @steps < 1
@mode = MODE_WAIT
# ?› ‰æ–Ê?Ä•`‰æ(‘Ò‹@Žž)
def refresh_wait
d = 2.0 * Math::PI / @item_max
j = i - @index
x = @cx + ( RING_R * Math.sin( d * j ) ).to_i
y = @cy - ( RING_R * Math.cos( d * j ) ).to_i
draw_item(x, y, i)
# ?› ‰æ–Ê?Ä•`‰æ(‰ñ“]Žž)
# mode : 0=”½ŽžŒv‰ñ‚è 1=ŽžŒv‰ñ‚è
def refresh_move( mode )
d2 = d1 / MOVING_FRAMES
d2 *= -1 if mode != 0
j = i - @index
x = @cx + ( RING_R * Math.sin( d ) ).to_i
y = @cy - ( RING_R * Math.cos( d ) ).to_i
draw_item(x, y, i)
@steps -= 1
if @steps < 1
@mode = MODE_WAIT
# ?œ ?€–Ú‚Ì•`‰æ
# x :
# y :
# i : ?€–Ú”Ô?†
def draw_item(x, y, i)
#p "x=" + x.to_s + " y=" + y.to_s + " i=" + @items.to_s
rect = Rect.new(0, 0, @items.width, @items.height)
if @index == i
self.contents.blt( x, y, @items, rect )
if @disabled[@index]
self.contents.blt( x, y, ICON_DISABLE, rect )
else
self.contents.blt( x, y, @items, rect, 128 )
self.contents.blt( x, y, ICON_DISABLE, rect, 128 )
# ?œ ?€–ڂ𖳌ø‚É‚·‚é
# index : ?€–Ú”Ô?†
def disable_item(index)
@disabled[index] = true
# ?› ?‰Šú‰»ƒAƒjƒ??[ƒVƒ‡ƒ“‚Ì?€”õ
def setup_move_start
@mode = MODE_START
@steps = STARTUP_FRAMES
if SE_STARTUP != nil and SE_STARTUP != ""
Audio.se_play("Audio/SE/" + SE_STARTUP, 80, 100)
# ?› ‰ñ“]ƒAƒjƒ??[ƒVƒ‡ƒ“‚Ì?€”õ
def setup_move_move(mode)
if mode == MODE_MOVER
@index -= 1
@index = @items.size - 1 if @index < 0
elsif mode == MODE_MOVEL
@index += 1
@index = 0 if @index >= @items.size
else
return
@mode = mode
@steps = MOVING_FRAMES
# ?› ƒAƒjƒ??[ƒVƒ‡ƒ“’†‚©‚Ç‚¤‚©
def animation?
return @mode != MODE_WAIT
# ? CLASS Window_RingMenu Ends
# ? CLASS Window_RingMenuStatus Begins
class Window_RingMenuStatus < Window_Selectable
def initialize
super(204, 64, 232, 352)
self.contents = Bitmap.new(width - 32, height - 32)
self.contents.font.size = $chara_select[5]
refresh
self.active = false
self.index = -1
# ?œ ƒŠƒtƒŒƒbƒVƒ…
def refresh
self.contents.clear
self.windowskin = RPG::Cache.windowskin($chara_select[4])
self.contents.font.name = $chara_select[0]
self.contents.font.color = text_color($chara_select[1])
@item_max = $game_party.actors.size
for i in 0...$game_party.actors.size
x = 80
y = 80 * i
actor = $game_party.actors
draw_actor_graphic(actor, x - 40, y + 80)
draw_actor_name(actor, x, y + 24)
# ?œ ƒJ?[ƒ\ƒ‹‚Ì‹éŒ`?X?V
def update_cursor_rect
if @index < 0
self.cursor_rect.empty
else
self.cursor_rect.set(0, @index * 80, self.width - 32, 80)
# ? CLASS Window_RingMenuStatus Ends
# ? CLASS Game_Map Additional Code Begins
class Game_Map
#Dubealex Addition (from XRXS) to show Map Name on screen
def name
$map_infos[@map_id]
# ? CLASS Game_Map Additional Code Ends
# ? CLASS Scene_Title Additional Code Begins
class Scene_Title
$map_infos = load_data("Data/MapInfos.rxdata")
for key in $map_infos.keys
$map_infos[key] = $map_infos[key].name
# ? CLASS Scene_Title Additional Code Ends
# ? CLASS Window_Location Begins
class Window_Location < Window_Base
def initialize
super(0, 0, $window_size[0], $window_size[1])
self.contents.font.name = $location_text[0]
self.contents.font.size = $location_text[1]
refresh
def refresh
self.contents.clear
self.windowskin = RPG::Cache.windowskin($window_location_skin)
self.contents.font.color = text_color($location_text[2])
self.contents.draw_text(4, 0, 120, 32, $location_text[3])
self.contents.font.color = text_color($location_text[4])
self.contents.draw_text(4, 32, 120, 32, $game_map.name, 2)
# ? CLASS Window_Location Ends
# ? Ring Menu - Show Player Location R1 - Ends
<a href="http://rpg_legacy.queroumforum.com/viewtopic.php?t=25">Fonte</a>
Editado pela última vez por helivelton em Qua Jan 02, 2008 8:18 pm, em um total de 1 vez.
Mensagem por blacktwister » Qua Jan 02, 2008 12:31 pm
legal, mas seria bom vc tbm colocar umais screens para mostrar como é esse tal menu, ou explicar o script, mas mesmo asim jah é alguma coisa e meius parabens pela iniciativa
Mensagem por Killer Ghost » Qua Jan 02, 2008 8:11 pm
Legal, eu conheço esse script, que modificou ele uma vez foi o Firewords, ficou bom pacas.
Bem, eu sugiro que você crie um padrão, helivelton, ao colocar scripts, está perfeito, mas, por exemplo, em todo o código, deixe-o em vermelho, por exemplo, para diferenciar do texto comum, já que não temos a tag code, e se tiver use-a.
Valeu. Ótimo trabalho.
Valariz
Registrado em: Sáb Mai 20, 2006 9:14 pm
Mensagem por Valariz » Qua Jan 02, 2008 8:46 pm
Ótimo trabalho campeão, continue assim. Eu já usei esse Ring Menu uma vez, não sei se é o mesmo script. O problema era que muito pequeno ele era, e quando apertava pra direita ia pra esquerda mas tudo bem, ótimo script.
Mensagem por helivelton » Qui Jan 03, 2008 8:29 am
Aqui nunca ocorreu isto valariz!
Mas oq vc usou era do help do xp?
esse não é o mesmo, esse tem mais coisas!
Logo irei postar um tuto, pra mudar os icones do menu!
Vash
Registrado em: Sex Jan 12, 2007 3:00 pm
Mensagem por Vash » Qui Jan 03, 2008 4:59 pm
Valariz tem a plena razão consciente, merece um doce...
Ring Menus são bem sexys, e dão tesão pra jogar, da um ar mais muderrno. Mas falta screens pra ver como isso fica na bos... digo no RPG Maker XP, meu maker preferido heeahhiauaiuae
Eu tenho medo do TUX...
